Author Topic: Wanted:  (Read 1861 times)
Offline Stevie
Wanted:
« on: June 18, 2004, 08:37:59 AM »
Hey everyone
i need to find a good strong engine
but heres the catch, i have not a lot of money.
tthats why i only want a long block cause if i were to get an alternator or anything else it would be a waste of my money cause i already got all that.
the engine needs to be for a type 1, and needs to run strong as i won't be able to afford repairs.
thanx alot and looking forward to some replys have a great day :)
Steve
GRAD 2004 woooohoooo
20's SORTA FIT!!
63 Beetle
Offline Hoosier Daddy
Wanted:
« Reply #1 on: June 18, 2004, 08:57:31 AM »
You might want to look at just rebuilding your old one. Probably run you about the same....just a thought.
Offline Stevie
Wanted:
« Reply #2 on: June 18, 2004, 09:51:03 AM »
well first off i don't have the knoledge to do it,
and i need an engine fast,
my old one seems to be knocking as if somethng is loose so i'm not sure how much internal damage there is.
Steve
20's SORTA FIT!!
63 Beetle
Offline volksbug
Wanted:
« Reply #3 on: June 18, 2004, 10:17:10 AM »
Check previous posting by R.Scott
« Last Edit: June 18, 2004, 10:17:31 AM by volksbug »
Offline Stevie
Wanted:
« Reply #4 on: June 18, 2004, 02:19:41 PM »
yeah but i don't need a complete engine.
only the longblock and the only other one is a type 3
i don't want to make any modification to any of my cooling tin
so a type 1 would be best candidate.
20's SORTA FIT!!
63 Beetle
Wanted:
« Reply #5 on: June 18, 2004, 02:25:22 PM »
my engine is comming out tomorrow morning hoping to drop it off at darrens later on in the day and see what kind of damage i have :(
hell i might even powdercoat the engine tin when it's out :D
make it all nice an pretty
russ
Offline Stevie
Wanted:
« Reply #6 on: June 21, 2004, 12:13:40 PM »
Bump:
 still lookin for a longblock....
anybody have one?
20's SORTA FIT!!
63 Beetle
Wanted:
« Reply #7 on: June 21, 2004, 12:18:41 PM »
I've got mine, 500 miles on rebilut 1641 T3 case. I know you said you don't want to modify tin, but it isn't hard. you only need a small hole for the dipstick adapter.
Offline Stevie
Wanted:
« Reply #8 on: June 21, 2004, 12:40:04 PM »
well the reason i don't want to modify tin is cause i only need this engine for a couple months and then i'm gonna be trying to build up something a lot bigger with a lot more power. and i would like to keep hole-less tin.
and i doubt i could afford the engine anyways.
but thank you..
steve
woohoo go grad 2004
20's SORTA FIT!!
63 Beetle
