Author Topic: Local crank refinisher recommendation?  (Read 13113 times)
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
« on: January 21, 2013, 06:01:49 PM »
Had a rod bearing fail on my crank and had to peel what was left of bearing off the journal. Need someone who can expertly assess the level of machining required and perform same. It's a balanced Berg 84mm with counterweights. Any favourites?
Jason Hamilton
Re: Local crank refinisher recommendation?
« Reply #1 on: January 21, 2013, 06:26:42 PM »
Give Dave at High Performance engines a call, Located just off Lougheed and Willingdon area.
Offline Lunchbox
« Reply #2 on: March 27, 2013, 02:29:50 PM »
wow those bearings are spun! I've seen it many times. Make sure that the crank isn't scored to far. I'd hate to say it but you may need a replacement crank.
Mike - 1980 VW RABBIT 1.8T Restoration
