Author Topic: Anyone have a 12 V plug in heater/defroster they'd recommend?  (Read 5171 times)
Offline ethanbanville
« on: September 25, 2012, 11:43:27 AM »
Hey, gang.
Moving up to Vancouver and don't want to spend the fortune it'd cost to put heat back in my So Cal bug. Between the new exhaust system I'd need along with all the new tin, I just don't have the time or the money. Anyone ever find one of those cigarette lighter plug in heater/defrosters that actually work?
Thanks!
Re: Anyone have a 12 V plug in heater/defroster they'd recommend?
« Reply #1 on: September 25, 2012, 01:26:35 PM »
Most of us have summer cars and winter cars up here. In winter the road salt will eat your So. Cal car for breakfast, lunch, and dinner. If your situation will allow, to keep your car So. Cal, I'd recommend parking your car over the winter. Just 2 cents worth.
« Reply #2 on: September 25, 2012, 02:07:32 PM »
Ha! Yeah, totally not going to let my car see the salt. Plan to put it away for the winter. The heater/defroster thing is more to pass inspection than anything. I grew up in Massachusetts so I know all to well what that salt can do to cars. My old 65 turned into swiss cheese! :-P
« Reply #3 on: September 25, 2012, 02:11:57 PM »
X2, although there are days after it's rained alot and no frost is forecast that the roads are salt free so you can go for the odd drive in the winter. But those electric units are pretty useless in a drafty bug, it's a little like trying to heat a warehouse with a candle, to make the BTU's you really need you'd need a generator in the back seat. Dress up warm and carry a little squeegee for the inside of the windshield if the car leaks. Keep watching the Canadian tire flyers as they usually start putting that stuff on sale fairly soon, if you can get one for cheap it may keep a peep hole in the windshield clear enough to see.
If it's just for inspection purposes some tubes from the fan shroud to the heat inlets on the body will likely do, not many non VW types actually expect heat to come out of the vents, as long as it blows air it'll likely be OK.
Offline Alp
« Reply #4 on: September 25, 2012, 09:36:32 PM »
I don't think you need them for our inspections.
« Reply #5 on: September 25, 2012, 09:43:38 PM »
I'm fairly confident there has to be some sort of defog system, whether it blew warm or cold wasn't the issue as long as the flow was noticeable at the windshield IIRC, if it came with it they need to see it or a reasonabe facsimile.
Anyone got a recent inspection sheet with all the boxes that need to be checked?
Offline Alp
« Reply #6 on: September 25, 2012, 09:54:34 PM »
on an old car?  Maybe something newer but I don't think they will check for it on an Provincial inspection.  I haven't had any of the cars I brought up checked for one.
« Reply #7 on: September 25, 2012, 10:03:19 PM »
Some shops will fail you without a defrost on the windsheild (as it must have one). It's upto the inspector to let it pass or fail without it.
Offline Cameron
« Reply #8 on: September 25, 2012, 10:39:09 PM »
The following list can be marked as Failed, Repaired after a fail and Passed.
Documentation
 •Vehicle identification
Driver’s controls
 •Horn
 •Mirrors
 •Windshield wipers
 •Windshield and windows
 •Windshield defroster
 •Visors
 •Interior heaters
 •Parking brake
 •Power brake operation
 •Brake pedal reserve and leakage test
 •Steering lash and travel
 •Power steering
 •Handle bars
 •Accelerator pedal
 •Transmission/speedo/Odom
Body integrity
 •Driver’s seat
 •Seat belts
 •Motorcycle seat
 •Doors
 •Physically disabled passenger vehicles
 •Reflex reflectors
 •Floors
 •Bumpers
 •Trunk
 •Trailer hitch
 •Body exterior / protruding metal
 •Motorcycle kickstand
 •Frame
 •Frame structural body
 •Unibody
 •Unibody structural integrity
 •Airbag – driver (rebuilt and new to BC – fail)
 •Airbag – passenger (rebuilt and new to BC – fail)
Undercarriage
 •Tires
 •Tire construction (mixed)
 •Wheels/nuts/studs
 •Road clearance
 •Steering linkage
 •Steering column and coupier
 •Kingpins
 •Ball joints
 •Springs and attachments
 •Shock absorbers
 •Wheel bearings
 •Fuel system
 •Exhaust system and catalytic converter
Brakes
 •Drum brakes
 •Disc brakes
 •Proportioning valve
 •Mechanical components
 •Brake lines and hoses
 •Master cylinder
Engine compartment
 •Hood and safety catch
 •Vacuum system
 •Power train
 •Fuel system
Pressure fuel
 •Liquid propane gas
 •Compressed natural gas
Lighting/Electrical
 •Battery
 •Switches
 •Visible wiring
 •Indicator lights
 •Lamps
 •Headlight/aim
There are a bunch of check boxes at the bottom of the form:
 •Vehicle has been road tested
 •Altered / modified
 •U-built
 •Replicar
 •Specialty vehicle
 •Amalgamated
 •Replikit
Offline Alp
« Reply #9 on: September 25, 2012, 10:46:27 PM »
Wow I am glad I have never run into an asshole inspector who looked for half that stuff...
Offline pittwagen
« Reply #10 on: September 26, 2012, 08:50:52 AM »
Princess Auto in Coquitlam has a 12 volt ceramic heater/defroster that should fit your needs. Base is adjustable. $24.99. Ask them for a thin magnet that you can superglue to the base.  Then you can mount in multiple locations on the dash. They will have the 12 volt lighter plug unit as well.  $40. should do it all in.  The Langley store will have the item as well if its closer.
Offline beetlemandan
« Reply #11 on: September 28, 2012, 07:01:30 AM »
youand me both..  both my beetles are missing a lot on that list.
the customer is always wrong
