Author Topic: FS: misc. engine parts  (Read 1368 times)
Offline patrickvw
« on: September 10, 2012, 04:00:43 PM »
Hey, I have a few things I would like to try and sell.
Pertronix billet Dist. w/ignitor 1 modual, flamethrower coil (40,000), pertronix 8mm plug wires- 60$ SOLD
scat solid shaft 1.25:1 rockers- $40 SOLD
Unknown brand solid shaft with unknown ratio rockers- $10
Bugpack 1 3/4 inch merged header-$40 SOLD
misc. standard headers- $10 each
EMPI C-Channel bolt on valve covers with beather vents $40 (gaskets not included)
Bugpack valve covers with breather vents $40 (gaskets not included)
Engle w120 cam (approx. 3000km on it) $25 (clearenced for use with my 84mm crank) SOLD
pair of 041 heads with 39intake and 32exhaust valves, 90.5 bore (needs exhaust port studs and maybe new valves)- $50 for the pair SOLD
2 1/2 inch drop spindles, never used, FOR BALL-JOINT FRONT END WITH DRUM BRAKE - BEETLE / GHIA 66-77 (EXCEPT SUPER BEETLE) PAIR- $50  (note-not used because you need a 2 inch narrowed beam)
I may have more stuff to post later. Also, prices are NOT firm. I am open to any offer. pictures avalable upon request.
Thanks for looking
Patrick
« Last Edit: September 11, 2012, 10:18:37 PM by patrickvw »
Offline robinson
Re: FS: misc. engine parts
« Reply #1 on: September 11, 2012, 04:39:00 AM »
where are you located  i would like the drop spindles and petronics dist
Offline Al H
« Reply #2 on: September 11, 2012, 06:35:58 AM »
Thanks for the pm Patrick  your pm  inbox is full so i couldnt respond back
Offline patrickvw
« Reply #3 on: September 11, 2012, 08:48:50 AM »
PM inbox is good now. My appolagies
