Author Topic: Brakes  (Read 17730 times)
Offline ray
Brakes
« on: May 06, 2012, 02:56:06 PM »
Okay a new section for a great club . Can someone chime in on what type of brake fluid I need . 1970 bug . Thinking DOT 3 ?
Re: Brakes
« Reply #1 on: May 07, 2012, 03:37:50 PM »
1970..? is the oval on a later pan or did you get a new car?
what's in there now? imho, i'd stick with it. it's probably dot3...which is fine. i'd reccomend a good long flush, bleed (if the system is opened) and inspection of all soft & hard lines, aswell as the master cylinder & wheel cylinders while you're at it.
ftr...stay away from dot 5. it doesnt play well with the other dots. ;)
