Author Topic: 4" Narrowed Beam?  (Read 4080 times)
Offline Johnnie B
4" Narrowed Beam?
« on: April 24, 2012, 07:12:09 PM »
Anybody know where I can get a 4 inch narrowed beam WITH shock towers and steering lock stops in Canada? I know I can get them in the States but the shipping is EXPENSIVE!
The 2 inch narrowed one I have now still makes my wheels stick out like a tractor!
JB
Custom Tattoos and Vee Double Yews!
Offline Chris W
  • Portland Oregon
Re: 4" Narrowed Beam?
« Reply #1 on: April 24, 2012, 08:32:09 PM »
Franklins in Seattle, drive down and pick one up!
Offline Russ
« Reply #2 on: April 24, 2012, 10:02:29 PM »
i have been debating heading down and getting one as well
heard nothing but good things about them
Offline Johnnie B
« Reply #3 on: April 24, 2012, 10:32:17 PM »
Good call, I'll talk to them tomorrow.
Offline Johnnie B
« Reply #4 on: April 25, 2012, 10:44:37 AM »
So it appears my maths skills alluded me yesterday and I actually have a stock width beam, hense the tractor appearance of the front end. Added to that the drop spindles and disc brakes and it looks retarded!!!
A road trip to Franklins seems to be in order for tomorrow.
Offline Chris W
  • Portland Oregon
« Reply #5 on: April 25, 2012, 10:53:13 AM »
This is my old car with a 4" narrowed beam from Franklins, CB Wide Five disc, drop spindles and 125's.
« Reply #6 on: April 25, 2012, 10:56:44 AM »
Call first to make sure they have stock!
« Reply #7 on: April 25, 2012, 11:48:01 AM »
Wasn't there a guy on this site that makes beams? Dirty Deeds or something?
Offline Johnnie B
« Reply #8 on: April 25, 2012, 12:26:10 PM »
I sent Dirtydeeds a message but he hasn't been active on here since Feb. Been trying to call Franklins all day but no answer.
I'm running 17x7's all round with 215's so I need to get the wheels in quite a bit. I think my tyres will still scrub with a 2 inch beam. As long as I can get a 4 inch with shock towers and a steering damper mount I should be all good. Combine that and 5 degrees neg camber on the front and I shouldn't have any problems.
Offline Russ
« Reply #9 on: April 25, 2012, 03:18:57 PM »
he's MIA
i think he's dealing with some family issues:(
i will try franklins as well
« Reply #10 on: April 25, 2012, 03:21:35 PM »
i have 16x7's all around and with a 3inch narrowed beam , drilled drums and i turned the camber nut to give me full neg camber i still had to roll the fenders. as for the rear the neg camber was just enuff to tuck them but thats again with the rolled finders and drilled drums.
i should have done the 4incher , but back when i had it done it was almost unheard of with the 3inch.
« Reply #11 on: April 25, 2012, 03:44:53 PM »
I talked to Dirty D, he's been busy but he will get back to you
Offline firebug
  • Travis A.
« Reply #12 on: April 25, 2012, 04:23:09 PM »
Wouldn't this one work?
http://www.cip1.ca/ProductDetails.asp?ProductCode=C26-401-017-4
I have it on my '57 and it seems to be fairly good quality. Not going to be as nice as the stuff from Franklins  but it does the job.
« Reply #13 on: April 25, 2012, 04:24:33 PM »
Frank makes a great Product.
« Reply #14 on: April 25, 2012, 06:46:57 PM »
Maybe I should get into the narrowed beam business.  What year a bug is this for?
« Last Edit: April 25, 2012, 06:56:37 PM by Jeremy »
Offline Johnnie B
« Reply #15 on: April 26, 2012, 07:46:22 AM »
No that one won't work as my 57 sits on a 70 pan. So I need a ball joint beam.
The rear sits perfect so I have no issue at the back at all.
I've done a bunch of measurements and with the amount of neg camber I am going to be running on the front (neg 5 degrees) I think a 2 inch will work. I don't want to lose the turning circle like you do with a 4 inch as this car will be seeing the track on occassion (hense the neg camber) and by track I mean real track where you actually drive around corners!
Thanks for all the feedback, it seems that this is going to be a gamble no matter which way I go.
« Last Edit: April 26, 2012, 07:53:17 AM by Johnnie B »
« Reply #16 on: April 26, 2012, 08:57:45 AM »
from lookin at your pics on F/B it apears that they are flush with the fenders, if so then 2" would work.
Offline rolls and pleats
« Reply #17 on: April 26, 2012, 05:29:02 PM »
A friend just picked up a 4" beam from Franklins and it is by far superior to KCW's beam.
« Reply #18 on: April 26, 2012, 11:44:26 PM »
Just curious. Whats the difference between the two?
Offline Johnnie B
« Reply #19 on: April 27, 2012, 12:24:23 PM »
STALKER!!!!
I measured it for one last time with a level and a depth gauge. The overhang was .5 of an inch and 1 inch to the inside fender lip so I decided to go for a 2 inch narrowed beam. The beam is in the car already, however I will not know the results until next weeks as my upper control arms are at Chassis Works in Chilliwack getting a little tweak for my camber.
I am so impatient!!!!
