Author Topic: FS: Split window, bay window parts  (Read 1447 times)
Offline busnerd
« on: April 23, 2012, 05:20:19 PM »
Looking to make some space in the garage.
Late bay heat deflector, good shape, straight with light surface rust.
Dual relief case came out of a '71 bus I had years ago, has threaded bosses for rear engine carrier,  crank included.
'64 bus engine cover, fair shape, not rusted out
Non doghouse fan shroud, single port fan (skinny), firewall tin, late bus (type 4) flywheel and pressure plate, type 4 bus alternator (not 70A), aftermarket oil cooler setup, shifter coupler
70A alternator pulley, two 70A alternator wiring harnesses
Would like to sell it all at once for $100, or I'll take offers on splitting it up.  Just want it gone!
« Last Edit: April 23, 2012, 05:26:32 PM by busnerd »
Offline jefftrish
Re: FS: Split window, bay window parts
« Reply #1 on: April 23, 2012, 06:48:39 PM »
If your in the lower mainland I'll take it all. If it's not gone allready.
Regards,
 Jeff
Offline jefftrish
« Reply #2 on: April 24, 2012, 04:20:16 PM »
Thanx, Clarke.
Awesome deal, thank you for the extras. Your bus is amazing, I cant believe it was painted almost 10 years ago, so strait for a home job.
Best Regards,
Jeff
Offline busnerd
« Reply #3 on: April 24, 2012, 04:47:01 PM »
Part are all Sold!
Gone to a good home.
Thanks Jeff.
