Author Topic: Wanted misc parts  (Read 3110 times)
Wanted misc parts
« on: November 28, 2011, 08:20:54 PM »
Need some bits for Manx I picked up.... Budget build just need some cheapy used parts
Front turn signals peanuts or bullets
Headlight switch
Ignition switch
Pair of 7-8" wide ET 5 spokes (torq thrust style) chev bolt
90.5 Pistons/Cyls
200 mm Clutch and pressure plate
Probably more to come
« Last Edit: November 30, 2011, 06:10:34 PM by josh »
Offline Jerome
Re: Wanted misc parts
« Reply #1 on: November 28, 2011, 09:06:45 PM »
i've got some 92mm cyls & pistons...
Sucks to your assmar.
« Reply #2 on: November 28, 2011, 09:10:41 PM »
Thick wall or old thin ones?
Offline Jerome
« Reply #3 on: November 28, 2011, 10:11:35 PM »
3mm so???......
Offline OldnShitty
« Reply #4 on: November 29, 2011, 10:52:47 AM »
I got 90.5's for a stroker crank, used...
Offline buggal
  • April McNicol
  • 1972 STD Beetle project
« Reply #5 on: November 29, 2011, 12:33:56 PM »
I have a steering column with a ign switch in it. 71' I think. It's marked swf something 71. It has a shaft too. Yours if you want it. I'm in Penticton.
« Reply #6 on: November 30, 2011, 06:10:04 PM »
3mm so???......
think im gonna go 4 90.5's thx
trying to stay stock stroke on this.......I have an 82mm crank and rods kicking around but if I build a stroker then I need carbs, bigger header, yada yada yada...... trying to keep this cheap and simple!
thanks but found one local
« Reply #7 on: December 20, 2011, 06:05:02 PM »
bump still need:
Ignition switch
60's stock gas tank or spun aluminum style
air filter for pict 34
« Last Edit: December 21, 2011, 05:06:24 PM by josh »
« Reply #8 on: December 20, 2011, 10:00:29 PM »
Josh:
see Clay on the Island. He has a new set os 90s new. Came with my 68 sale. Probably at a good price.
Best of luck .
« Reply #9 on: December 21, 2011, 05:05:56 PM »
Josh:
Best of luck .
Picked those up today thx
