Author Topic: irs swap  (Read 1372 times)
Offline beetlemandan
irs swap
« on: October 04, 2011, 09:21:42 AM »
i finally scored a 73 irs tranny for my 69 beetle but i know the size of the case is bigger and the nose cone mount is way different. whats involved in the swap?
the customer is always wrong
Re: irs swap
« Reply #1 on: October 05, 2011, 10:36:54 AM »
The case is the same size.
Take the nose cone off your old trans and put it on the new one.  You must first check for clearance between the top bearing on the gearbox and the nose cone.  The later nose cone has this clearance cast in.
You also must upgrade your clutch.  Remove the center ring from the clutch.
The later trans uses a different TO bearing, so if it didn't come with one, you'll have to buy the late type TO bearing.
Re: irs swap
« Reply #2 on: October 05, 2011, 06:24:03 PM »
ugh.. i have to buy sonething :'(
