Author Topic: looking for a way to get the window wipers to work with switch  (Read 11661 times)
Offline lildunebuggy
« on: September 17, 2011, 04:50:18 PM »
i have a 73 sb baja i need to have wipers to drive it to work and back. tell i can find a truck. was wondering if anyone has a wiring diagram that will help me with a simple way to get wipers without the stock switch. it is shot so it will not work. all i need is hi and lo and off i am hoping the wiper motor is not gone aswell. thanks looking for the best answer. maybe even a drawing haha i have lots of parts and stuff but just the simple ones please
Re: looking for a way to get the window wipers to work with switch
« Reply #1 on: September 17, 2011, 05:24:44 PM »
Assuming you mean a common toggle switch connect one terminal to the fuse box and the other to 53 or 53b (black or black/yellow), with the motor body grounded it should work. Don't expect 2 speeds or for it to park when you shut it off but you'll have wipers. The OG switch is a complex unit so it'd take 3-4 toggle switches to duplicate it and if you switched on one without turning the other off first you'd get smoke.
