Author Topic: 1600 S/P Engine complete Turn key **Sold**  (Read 1946 times)
Offline Darren
« on: September 07, 2011, 07:46:53 PM »
Hi this is a 1600 Single port that is complete tun key ready to go, I pulled off all the tin and gave it a clean up, the heater boxes are in great shape, the Carb and choke works perfectly,heat riser passages in the manifold are clear. It has a 009 with new points and condensor,
New Ignition Wires and Coil,New Fuel pump and a new Header with Muffler that has tail pipes in stock location. It runs great the compression was 105,110,115,115,  Also has a good clutch and pressure plate with it.
Can be seen running.
$650
Thanks  Darren
« Last Edit: September 15, 2011, 07:47:25 PM by Darren »
Re: 1600 S/P Engine complete Turn key
« Reply #1 on: September 08, 2011, 06:02:29 PM »
that is a great deal
Offline Darren
« Reply #2 on: September 13, 2011, 01:00:08 PM »
The prospective buyer has changed his mind, so it's back up on for sale!
Offline getgeoff
  • Geoff
« Reply #3 on: September 15, 2011, 09:36:35 AM »
PM sent
60 11 Window bus Lt grey
55 Wolfsburg Kombi doveblue
55 Beetle ultra maroon
