Author Topic: FS: Beetle parts  (Read 3415 times)
Offline 72vdub
FS: Beetle parts
« on: August 22, 2011, 08:13:29 AM »
I have some miscellaneous beetle parts that are in need of new homes. You name your price need gone.
1) A pair of d/p heads with fresh valve grind. comes with rocker arms, push rods and valve covers included
2) 3 stock used piston/cylinders in good condition
3) Stock flywheel, needs to be cleaned up a bit but otherwise in good condition
4) 34 pict 3 carb, for rebuild as it is missing the small adjuster screw.
5) Weber W224051 Carb (use as is or rebuild).
6) A pair of stock b/j spindles good condition.
7) Fresh air box (no controls)
8 ) Front and rear bumpers off of 72 beetle, front one has holes cut for turn signals.
9) Driver side mirror 68 up needs glass
10) License plate light housing
hans.gorden@gmail.com
« Last Edit: September 10, 2011, 08:01:33 AM by 72vdub »
Offline 72vdub
Re: FS: Beetle parts
« Reply #1 on: August 28, 2011, 07:45:14 AM »
bump
Offline 72vdub
« Reply #2 on: August 31, 2011, 08:21:19 AM »
Will consider trades for WHY beetle parts.
« Last Edit: August 31, 2011, 08:27:34 AM by 72vdub »
Offline Ramunn
« Reply #3 on: August 31, 2011, 08:57:40 AM »
I have a ton of stuff I will trade for the heads
Offline 72vdub
« Reply #4 on: August 31, 2011, 11:04:33 AM »
What do you have that you are willing to trade for them? any pics?
Offline Ramunn
« Reply #5 on: September 01, 2011, 11:17:22 AM »
I have a new Grant Steering wheel and hub for your Beetle call me 250-212-3157
Offline 72vdub
« Reply #6 on: September 07, 2011, 09:32:00 AM »
bump
Offline 72vdub
« Reply #7 on: September 13, 2011, 10:26:43 AM »
bump
Offline 72vdub
« Reply #8 on: October 03, 2011, 11:58:28 AM »
going up
