Technical
Engine Tech Forum
Timing
Topic: Timing (Read 10279 times)
66split
Timing
August 14, 2003, 09:42:06 AM »
Hey all...I have a 1776 with a pertronix ig and coil and a new dizzy. When I line the degreed pulley up to zero, and the piston #1 is at tdc my rotor does not point to the number one firing position but a few degrees before it...what gives..
Timing
August 14, 2003, 05:23:53 PM »
Rick,
sorry i can't answer your question i was just curios if you and the bus will be making the show this weekend??
Raymond
Timing
August 14, 2003, 06:38:32 PM »
I'm not sure how you can visually tell if its out only a few degrees. With the cap off, the blunt nose of the rotor probably covers 15 degrees. Was your distributor drive correct before the distributor swap?
Technical
Engine Tech Forum
Timing
