Author Topic: Compression Test  (Read 6211 times)
Offline Thomas
Compression Test
« on: July 16, 2011, 06:38:15 PM »
I did a compression test on my 1641 tonight.
1-135
2-132
3-130
4-145
Not sure if these number are good or bad. I know that over 120 is usually good but not sure how much of a spread is OK 130-145?
Thanks Tom
Re: Compression Test
« Reply #1 on: July 16, 2011, 07:04:23 PM »
If it was me I would be happy with that.  I have a T4 here with 90 - 95 psi on it, and it still runs, and starts fairly well too.
« Reply #2 on: July 19, 2011, 11:47:51 AM »
yup those are some solid #'s but you may want to do a "leak-down test" as well. this is a better way to check the condition of your rings
Offline Thomas
« Reply #3 on: July 19, 2011, 09:34:11 PM »
What is a leak down test? Can I assume that it how long the cylinder will hold the pressure?
« Reply #4 on: July 19, 2011, 09:54:19 PM »
A leak down test uses a tool with a fixed orfice, compressed air is blown into the cylinder at a known rate and pressure loss past the rings or valves is measured. sometimes called a bleed down or differential pressure test.
Offline buggal
  • April McNicol
  • 1972 STD Beetle project
« Reply #5 on: July 28, 2011, 10:55:28 AM »
Or there's a simpler less informative test to determine whether it's rings or valves.
Do dry compression test, then one cylinder at a time, squirt a little oil in the cylinder and repeat the test. If the compression comes up it's rings, if not it's valves.
Don't use too much oil or the test is useless, just use a squirt or two, enough to help seal around the rings. It can give you a place to start.
Offline buggal
  • April McNicol
« Reply #6 on: July 28, 2011, 10:57:12 AM »
Oh yeah, I am a licensed mechanic. Most guys don't take advice or suggestions from a woman, but I got my license in 1985 so I do have some experience.
Good luck.
« Reply #7 on: July 28, 2011, 05:19:20 PM »
Its a good thing your not a woman then.....
Offline buggal
  • April McNicol
« Reply #8 on: July 28, 2011, 05:55:59 PM »
I'm not the one who said orifice.... wee_hee
