Author Topic: starting and firing problems  (Read 12013 times)
Offline lildunebuggy
« on: July 16, 2011, 03:39:18 PM »
i have a baja that i am working on. i have rebuilt the motor and trying to get it running. have new carb fuel pump and 009 distri and wiring just bought new plugs and points funny was a new distributer. turns over and has no sprak thinking all this is new timing is right. looking for anwsers on anthting i have over looked. timing is good and power is good and looking on finding anything else that may cause this to not fire.
Offline 52 split
Re: starting and firing problems
« Reply #1 on: July 17, 2011, 06:24:00 PM »
the basics are fuel,compression,spark, you should then get ignition,check to see your valves are set right,is the point gap correct, and do they open. are you running a pertronics setup, if so you may have put the hot wire on the wrong  side and fried the unit.it only needs to be on for a moment and its toast.  :'( hope this has been some help.
