Author Topic: FS: 15x10 Wheels, Side pods, stock bits -Updated- new items and reduced prices  (Read 2221 times)
Offline 66DB
Pair of 15x10 Baja wheels, brand new in the box NEVER been used or mounted. They're $100 each @cip so $130 for the pair is fair?
Flat side pods for a dune buggy (see pic below) great for an offroad buggy - $40
King and link steering box, has a little play (could be adjusted? - I just put in a new spare I had lying around) and the pitman arm was drilled out for 1/2" tie rods - $30
Lots of random engine bits, carbs, shrouds, intakes, starters, fuel pumps. Other - swing axle torsion bars and plates, backing plates (I'm pretty sure they're all rear), stock 4bolt and 5bolt wheels - Tell me what you need I might have it, make an offer just need it gone
Pic is of side pods only not the wheels or buggy
« Last Edit: May 17, 2011, 02:22:39 PM by 66DB »
Offline goldfish
Re: FS: 15x10 Baja wheels, flat side pods, stock engine bits
« Reply #1 on: May 11, 2011, 04:45:37 PM »
Are the baja wheels 4 or 5 bolt? Do you have a picture?
'65 Type 1
Offline Ace-Vw-Herbie
« Reply #2 on: May 11, 2011, 05:31:22 PM »
Hi ,looking for backing plates for a  link pin front end .     Thanks Ace 604-533-6722
Offline 66DB
« Reply #3 on: May 11, 2011, 06:27:57 PM »
Oops forgot that. They are 5 bolt and are white. They are the ones from CIP:
http://www.cip1.ca/ProductDetails.asp?ProductCode=ACC-C10-1018
I'll have to go take a look to see which ones I have exactly, I'll give you a ring if I find link pin plates
Offline getgeoff
  • Geoff
« Reply #4 on: May 11, 2011, 07:46:02 PM »
What year are the spring plates and torsion bars?
60 11 Window bus Lt grey
55 Wolfsburg Kombi doveblue
55 Beetle ultra maroon
Offline 66DB
« Reply #5 on: May 11, 2011, 08:19:00 PM »
I'm not actually sure what year they are, they came off the buggy when I converted to IRS. They are for a swingaxle trans - is there a difference between years, or is there a way to check?
Offline 66DB
