Author Topic: alternator nut problems!!!  (Read 5868 times)
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« on: April 19, 2011, 01:22:12 PM »
Are the alternator nuts and cupped spacers (or washer?) on the pulley end, the same for an alternator and a generator? thanks !!!  PDT_Armataz_01_37
Re: alternator nut problems!!!
« Reply #1 on: April 19, 2011, 04:18:46 PM »
The nut and shim washers are the same.
And  I think the cup spacer is too.  Although I know there are 2 different heights.  One is a couple mm taller.
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« Reply #2 on: April 20, 2011, 12:18:55 PM »
thats not what i wanted to here! I'm having trouble getting my pulley on my alternator.  I have a cup spacer off a generator, but when i try and put it on the alternator it sticks out to far and there are no threads to put the nut on?  i'm guesing my afermarket pulley is thicker than s standard one?  Does an aluminum pulley require a diffrent cup spacer? I guess this is the question I should of asked in the first place!!
this is the pulley I have?
http://www.cip1.ca/ProductDetails.asp?ProductCode=C13%2D33%2D1041
thanks!!! You_Rock_Emoticon
