Author Topic: Turbo Exhaust/coatings.. What Holds Up?  (Read 1603 times)
Offline Boost_Retard
« on: May 18, 2004, 06:02:40 PM »
hey everyone..spent the day messing around with the car again..
got my turbo exhaust ready to go..i was planning on having it ceramic coated..
but i wanted to know if the ceramic coating will hold up to the heat of the turbo exhaust system..or if its better to leave the tubes Raw..or use a high temp paint..or just header wrap..
and if i was to have it ceramic coated..would there be any problem in having the tubes done after say the motor has run for a break in period? or does the metal need to be fresh?
thanx
Cale
« Reply #1 on: May 18, 2004, 08:02:51 PM »
Ceramic is the way to go!
Wraps will prematurly rust your pipes, high temp paint is for BBQ's and there will be less prep/money involved if the pipes are \"fresh\"
« Reply #2 on: May 18, 2004, 11:07:55 PM »
the coaters wont want to work with a used header
think of all the carbon on the inside they have to get rid of
-dan
