Author Topic: Beam Adjusters  (Read 3740 times)
Offline SINGLECAB
Beam Adjusters
« on: May 17, 2004, 12:09:51 PM »
I have an adjustible beam in my bus but I can't tell if it is at its highest or lowest position. The adjusters are at the lowest position on the beam right now. So is the adjuster at it highest or lowest vehicle height setting now?
Beam Adjusters
« Reply #1 on: May 17, 2004, 12:23:05 PM »
i believe that would be the lowest setting
Beam Adjusters
« Reply #2 on: May 17, 2004, 01:59:49 PM »
On mine it is at the lowest height when the adjusters are at the highest point. But it does depend on which way the adjuster are facing, to the rear or to the front?!
« Last Edit: May 17, 2004, 02:00:47 PM by 1976BUS »
Offline SINGLECAB
Beam Adjusters
« Reply #3 on: May 17, 2004, 03:49:09 PM »
My adjusters are facing to the rear of the vehicle. From the looks of it, the adjusters are to maximum height, but i can't get them to move either way so i'm not sure. :blush:
Beam Adjusters
« Reply #4 on: May 17, 2004, 04:56:25 PM »
if your adjusters face the rear then they would have to be at the highest position to be at the lowest vehicle height. What type of adjuster are they?
