Author Topic: Dry Sump Help?  (Read 4345 times)
Dry Sump Help?
« on: March 05, 2011, 01:27:13 PM »
Wondering if anyone here has experience with Dry Sump setups for Type 1?
Specifically I'm wondering about:
- CB Dry-Sump pump vs. the Bugpack unit...advantages/disadvantages of both units. (can't find anything on the Samba or simliar)
- Oil Line Sizing. My current setup uses -8AN lines for the full flow oil setup, but I understand that to ensure proper oil pressure you need to offer about 3x the supply to the pump. So as I understand it I'll want to modify what ever pump/tank I get to run a -12AN feed line to the pump, and -8AN following. Right?
(for those who are wondering, the next project can't use a deep sump, thus I have to use a dry sump system)
Re: Dry Sump Help?
« Reply #2 on: March 06, 2011, 09:23:48 AM »
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=3&t=10351
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=3&t=8411
not sure if these will help but these guys seem to use dry sump often . I think there may be more on the topic in that forum somewhere.
Re: Dry Sump Help?
« Reply #3 on: March 06, 2011, 11:30:24 AM »
give me a call , i have been resurching this for a bit and will be going that route either this motor or next depending on time .
at home today .will pm you my number
