Author Topic: SOLD!!!  (Read 1973 times)
Offline 72 slambug
  • Junior Member
SOLD!!!
« on: February 27, 2011, 10:40:18 AM »
I've pulled my old engine out and am building something bigger. This engine would be best for parts. It was running when I pulled it but has one of the sump screws in the case buggered. Now it leaks... However it has tons of new parts on it to salvage including:
-new 1600 dual port heads(stock)
-engle 110 cam
-kadron dual 34 carbs brand new used for 500 km's
-newer generator
-monza 4 tip exhaust
-009 distributer
-bosch blue coil
-chrome fan shroud
-new spark plugs
-new pistons pots and rings (cofap)
- comes with flywheel & clutch
It's basically turn key but the sump leaks and it'll need an oil cooler. I have an external cooler setup with aircraft fittings that can be included as well. I'm selling the complete package only I will not part it out!
I'm asking $800 bucks and the price is pretty firm.
Phone calls are best
604-897-2177
Kris
« Last Edit: March 13, 2011, 07:33:02 PM by 72 slambug »
Re: FS: complete dual port 1600 for sale (parts engine) lots of new parts
« Reply #1 on: March 02, 2011, 05:51:11 PM »
If anyone picks this up, I've got a good case that I'd be willing to sell.
Between the two you'd have a good motor.
Offline Bubba
« Reply #2 on: March 04, 2011, 04:38:46 PM »
I drilled and through bolted my sump to my case...you shouldn't scrap yours because of a messed up thread.
Just my 2 cents.
64 Beetle
86 Nissan Multi
81 Rabbit
90 Malibu Euro F3
94 H-D FXDWG
Offline 72 slambug
  • Junior Member
« Reply #3 on: March 06, 2011, 01:19:43 PM »
Just my 2 cents.
I've already drilled it out and put in a oversized stud. The same one is leaking again. I'm sure someone could fix it or bolt on a sump for sure.... but I'm building a 1914cc for this car and the 1600 has gotta go!
