Author Topic: need help with karmen  (Read 1738 times)
Offline pete-stevers
« on: December 31, 2010, 03:56:34 PM »
i am looking to squeeze the widest rim and tire combo under a 65 karmen...
i know a set of 15x6 fuches will work...but will 15x7s??
and will i be able to fit a 15x50 225 in the rear....or am i dreaming
i dont want to pull the quarters,
thanks guys
i know this is tire and wheel...but not much moves down there
Re: need help with karmen
« Reply #1 on: December 31, 2010, 11:20:09 PM »
If you're talking about a Karmann Ghia (the Brits call a convertible Bug a "Karmann"), there's no way you will fit that tire without narrowing the torsion housing.
When I ran that tire on my Beetle, I had 3mm of clearance to the spring plate, and I pulled the wheel arch out a tiny bit.  Beetles have way more room than a KG.
6" Fuchs will fit, but you can't use wheel adapters.  A 195/65 will work.
There's no e in Fuchs.
« Reply #2 on: December 31, 2010, 11:29:50 PM »
unless you talk about E's fuchs wich still for sale. :D
« Reply #3 on: January 02, 2011, 10:46:19 PM »
thanks eg...ive got to many 16x7s fuchzzzzzzz
opps sorry bruce..ieeeee :P
« Reply #4 on: January 02, 2011, 10:47:26 PM »
any other guys with thoughts...
« Reply #5 on: January 02, 2011, 11:21:23 PM »
I have seen late 7s on an early Ghia with short axle.  But that's with a small tire.
