Author Topic: 34-pict With 009 Dist.  (Read 9105 times)
Offline Mike Scott
« on: August 09, 2003, 03:57:05 PM »
Ok, I've been battling with this thing for weeks. Are the flat spots I experience during acceleration normal with a stock 160DP using a 009 dist.?
« Reply #1 on: August 09, 2003, 04:52:38 PM »
Yup, 009 will give a bog when used with that carb. Some fine tuning can help eliminate it but it can take a while.
Offline 65_bug
  • Junior Member
« Reply #2 on: August 09, 2003, 05:52:25 PM »
I had the same problem with my set up (34 pict with 009). I cured the problem by buying a centre-mount dellorto 45 DRLA. It fixed all flat spots and hesitations.
Offline mackerr
  • Junior Member
« Reply #3 on: September 04, 2003, 01:55:31 PM »
I also had this problem and seemed to solve it after adjusting the idle mixture at a shop with a gas analizer. The mixture was adjusted to pass air-care and after passing was re adjusted to eliminate the flat spot.
« Reply #4 on: February 16, 2006, 07:16:42 PM »
How do you adjust for air care with ( 34poct & 009) that setting?
Emilio
« Reply #5 on: February 16, 2006, 07:25:38 PM »
Emilio
with a gas analyzer.
Offline buggysam
« Reply #6 on: February 16, 2006, 07:47:29 PM »
i put a rivet in the hole in the throttle plate to improve the airflow thru the idle circit .... it seemd to help lots
