Author Topic: clutch/pressure plate combo for 1200 bolted to IRS trans  (Read 6834 times)
« on: December 21, 2010, 04:53:38 PM »
So I've bought a running 1200cc engine to throw in the '59 to putt around in for now. (Emphasis on putt) The question I have is since I've converted it to IRS do I have to change the pressure plate and throw out bearing or can I bolt the engine right up and let er fly? (Other than using a 6v starter and a 12 generator and coil)
Jeremy
Re: clutch/pressure plate combo for 1200 bolted to IRS trans
« Reply #1 on: December 21, 2010, 06:32:38 PM »
Depends on what your throwout bearing looks like, does it ride on a sleeve that surrounds the input shaft or just hang on the release levers? If it doesn't have the sleeve the pressure plate needs the ring in the center.
« Reply #2 on: December 21, 2010, 07:50:00 PM »
Thanks for the reply BUSSDADDY. The throw out bearing rides on the sleeve. Can I remove the ring on the PP? If not can I remove the sleeve?
Offline notchback
« Reply #3 on: December 21, 2010, 09:18:49 PM »
Remove the ring on the Pressure plate if you can. Im not too sure if those ones will come apart
Bruce McCrindle
AIRCOOLED WERKS
6047245576
New phone number above
« Reply #4 on: December 21, 2010, 10:29:26 PM »
Thanks Bruce. I'm out of town so can't run into the shop to take a look but I do remember looking at it and wondering how to take the ring off if I had to. Maybe I could trim the TO bearing sleeve to make it work.
« Reply #5 on: December 22, 2010, 06:55:16 AM »
The sleeve in the bellhousing unbolts, but then you'll need the early TO bearing, flip a coin, change the bearing or change/modify the PP.
That ring comes out of most of the diaphram style PP's I've seen, it's a big flat pressed on circlip inside that has to come off, wear goggles while you pry as the clip shatters sometimes ;)
« Reply #6 on: December 22, 2010, 08:22:01 AM »
Thanks for the info guys. Thats exactly what I wanted to know.
« Reply #7 on: December 22, 2010, 08:26:46 AM »
If you go this route you will also need to change the cross shaft! It makes it a little more work.
« Reply #8 on: December 22, 2010, 09:43:54 AM »
Sorry. Which route are you talking. Replace the TO bearing or PP ring.
« Reply #9 on: December 22, 2010, 10:20:20 AM »
Oooops, Geoff's right, if you remove the sleeve and change the TO bearing the cross shaft is different too, the simple fix is pry the ring out of the PP and go for a drive :D
« Reply #10 on: December 22, 2010, 11:27:11 AM »
Thanks guys. All cleared up. Going for a drive sounds great. It's about time I think. Only been 20 years since  I drove this beater .
