Author Topic: Broken Nut  (Read 6634 times)
Offline mizovalgrl
Broken Nut
« on: December 12, 2010, 10:23:15 PM »
Can anyone suggest how I can get the bottom half of my nut out? I did it up to tight....It is the nut on the rim..Thank's
Re: Broken Nut
« Reply #1 on: December 13, 2010, 10:03:19 AM »
This requires a pic.
Offline mizovalgrl
Re: Broken Nut
« Reply #2 on: December 13, 2010, 03:45:07 PM »
I guess that would help....I will put one up...Thank-you.
Offline piercedvw
  • aka Karmann Ghia
Re: Broken Nut
« Reply #3 on: December 14, 2010, 08:31:22 AM »
Did you break it off?
You can:
-heat it up
-use vise grips
-cleanup and double nut the end and impact it off..
or a combo of a few things..  A pic of the damage would help yes.
Re: Broken Nut
« Reply #4 on: December 14, 2010, 12:25:47 PM »
if it's the wheel bolt, i've had to drill one out on one of my drums.... i went small bit, larger, and larger until I got near to the threads, then carefully chiselled the threads out, and a final pass with the right sized tap to clean it out.
brian Waz
Offline Alp
Re: Broken Nut
« Reply #5 on: January 09, 2011, 09:53:51 PM »
you need to take it easy on the old man's nuts there girlie......
