Author Topic: fuel gauge problem  (Read 8142 times)
fuel gauge problem
« on: November 12, 2010, 07:38:26 PM »
is there a way to find out wich one the culprit is? (sender,vibrator,fuel guage)
when ignition is on the fuel needle will move a millimeter if that and stay there .
i did replace my speedo and used the fuel gauge that came with it, but used my old vibrator and the sender... i did keep my old guage so i could swap out , but just want to know if theres something i can do to test each one?
« Last Edit: November 12, 2010, 07:40:02 PM by buddy boy »
Re: fuel gauge problem
« Reply #1 on: November 12, 2010, 07:40:57 PM »
and yes i did check if there is gas ,.. full tank.
« Reply #2 on: November 12, 2010, 08:15:37 PM »
does it work with the og guage?
mismatched sender....
« Reply #3 on: November 12, 2010, 11:57:40 PM »
the new speedo is out of a '74 , and mine was a '75,..so it should be ok ?.... i'm gonna put my old guage back in and go from there,.
i'm wondering if there is a way to "test" the sender/vibrator/guage to single out wich one it is.
« Reply #4 on: November 13, 2010, 12:00:41 AM »
Pull the sender out and connect it up to an ohm meter.  Then lift the arm through it's travel very slowly.  The resistance should not jump around.
If you don't have an ohm meter, you can eyeball the windings for breaks.  Sometimes a magnifying glass is needed to see inside.  If there's a break, it's junk.
If you buy a new one, spend the extra $10 from CIP to get the good VDO one.  I waited almost a year while they were out of stock, so I gave up and bought the mystery brand part.  It was utter garbage.  The first problem was that the float had a hole in it, so it immediately sank.  I put the float from a German sender in it, then it worked.  But only for a handfull of months, then it burned out.
« Reply #5 on: November 13, 2010, 11:14:17 PM »
ahh? totally not what i thought i would read on a upstanding vw site
« Reply #6 on: November 14, 2010, 04:19:54 AM »
:wub:
« Reply #7 on: November 17, 2010, 11:12:51 AM »
the float in my old mexi one was full of gas !!,.. causing it not to rise
got the good vdo one from cip1 and everything is good !
