Author Topic: more h.p.  (Read 14791 times)
Offline krammit
  • live life to the fullest
more h.p.
« on: October 24, 2010, 06:12:54 PM »
is there any way to get more h.p. other than put bigger pistons in.I have a 1776 but wouldn't mind more umphff.the guy that built it for me said that I will want more eventually.I also want to know if you need other than stock cv joints with more hp.(1900 or so)
Re: more h.p.
« Reply #1 on: October 24, 2010, 06:14:54 PM »
Please give us a little miore info on your current set up, carb or carbs? what dist? exhaust? cam? ratio rockers? all this will help us tell you what can be done to increase your HP.
Re: more h.p.
« Reply #2 on: October 24, 2010, 11:37:25 PM »
Also, what heads are on it.
What are you going to do with the car?  Drag racing with slicks?
Offline krammit
Re: more h.p.
« Reply #3 on: October 26, 2010, 12:41:29 PM »
vw guy built it and told me the only mods on it are the carbs( dual kads) and the exhaust, other than that I'm guessing everything else is stock.
Offline kris urban
  • my beautiful baja bug that gets things done
Re: more h.p.
« Reply #4 on: May 06, 2011, 01:38:07 PM »
easy yo get more horse power, 1st give it a tune up that can add 7-10 hp, then u can put a stinker exhaust or straight pipe it, then u cen put hot plug in but risk breakign some things, then u can put a super chrager and then the rest is pretty much internal of then egine ,up graded cam lifters  valves ect ect
Re: more h.p.
« Reply #5 on: May 06, 2011, 03:10:47 PM »
this guy came outta left field !!!...lol
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
Re: more h.p.
« Reply #6 on: May 06, 2011, 07:09:15 PM »
Jason Hamilton
Re: more h.p.
« Reply #7 on: May 06, 2011, 08:55:21 PM »
Re: more h.p.
« Reply #8 on: May 06, 2011, 09:04:28 PM »
Re: more h.p.
« Reply #9 on: May 06, 2011, 09:23:04 PM »
actually, he  might be right ,.. here is a video that explains how to squeeze a few pony's out of a 1600dp
http://www.youtube.com/watch?v=oHg5SJYRHA0&feature=related
« Last Edit: May 06, 2011, 09:25:57 PM by buddy boy »
Offline kris urban
Re: more h.p.
« Reply #10 on: June 10, 2011, 08:07:54 PM »
trash talk what u can... i know my stuff if youd like to race
Re: more h.p.
« Reply #11 on: June 21, 2011, 04:17:57 PM »
LOL Nice You_Rock_Emoticon
Offline 52 split
Re: more h.p.
« Reply #12 on: June 22, 2011, 08:56:04 PM »
it would not be much of a race if your engine still runs backwards as per your most recent help post.as for the og post other than some ratio rockers there is not much more for bolt on hp. 1776 is a nice easy to maintain engine. ie less dollars spent, more time driving.bigger engines bigger heartaches, if you can not do all the work yourself. there is no such thing as a $500.00, 150 hp motor for sale used or new. just my 2cents ;)
Offline Jerome
Re: more h.p.
« Reply #13 on: June 22, 2011, 11:26:17 PM »
There are actually a lot of options out there for you. You could try this modification.
http://www.youtube.com/watch?v=wQM_TyyRye4&feature=autoplay&list=PLEACA39FD7AE6F1C2&index=11&playnext=11
Sucks to your assmar.
Offline mizovalgrl
Re: more h.p.
« Reply #14 on: June 22, 2011, 11:56:25 PM »
This post is great....very informative keep it coming.When is the duel going to take place?
Re: more h.p.
« Reply #15 on: June 23, 2011, 01:56:38 PM »
Here ya go...
- FRIDAY AUGUST 26th -
12th Annual DVKK "Strip Show"
Start the weekend off right with Drag Racing at Mission Raceway Park on Friday, August 26th. $1000 in Cash Payouts! Gates open at 5pm and racing runs until dark. Open to all VW's (Air & H2O) and any other street cars that pass tech. Stock VW motor challenge class will be back once again this year (sponsored by Zündfolge Car Club)
Offline kris urban
Re: more h.p.
« Reply #16 on: June 29, 2011, 11:36:56 AM »
sick im down
Re: more h.p.
« Reply #17 on: June 29, 2011, 05:26:55 PM »
....i know my stuff if youd like to race
We'll see what you're made of come race day.
Re: more h.p.
« Reply #18 on: June 30, 2011, 05:44:39 PM »
Wait 'till I show up with my 1200cc of fire breathing fury!!! I'll take you all on.
Re: more h.p.
« Reply #19 on: June 30, 2011, 07:26:04 PM »
hehehe.....1600cc  engines can go fast you know guys  lol_hitting   Maybe we'll see a low 10 this year with a 1600cc powered beetle?   ;D ;D   I might have to enter the stock "modified" engine challenge if Silas will bend the rules abit.
Offline GMB
Re: more h.p.
« Reply #20 on: August 11, 2011, 09:52:48 AM »
"is there any way to get more h.p. other than put bigger pistons in.I have a 1776 but wouldn't mind more umphff.the guy that built it for me said that I will want more eventually.I also want to know if you need other than stock cv joints with more hp.(1900 or so)"
Hey Krammit you can add a set of street style 1.25:1 ratio rockers and a heavy pulley. This will give you more bottom end torque (drivability). These can be transferred easily to a 1914cc later.
A capacitive discharge ignition will add to the combo as well. Something like an MSD 6 with multiple capacitive discharge really helps with bottom end, emmisions and drivability and can be used on any size engine.
I bet those carbs could use setting and jetting as well! That always helps.
Gary.
« Last Edit: August 11, 2011, 09:54:35 AM by GMB »
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
Re: more h.p.
« Reply #21 on: August 11, 2011, 08:44:44 PM »
I use Stock CV's in my rail I clearanced a bit for a little more travel. They were used when I pput them in and now their used and abused Just ask GMB!  :DI have a 1914 (going 2275 I now have all the parts for) I've pulled S@#t loads of stuff out of some crazy places, CJ's, SUV's and touch wood all has been good!
Gary
Re: more h.p.
« Reply #22 on: August 11, 2011, 08:55:16 PM »
My stock cv's that were also used,  were good to high 11's in the 1/4 running slicks.  Once I was running deep 11's then they were breaking every other run.  So I would say you are good up to 180 hp using type 1 cv's.
