Technical
Electronics & Car Audio Forum
reverse light wiring
Topic: reverse light wiring (Read 7598 times)
buddy boy
Marked for life
October 10, 2010, 12:10:41 PM »
need to know where the wires travil through starting from the tail lights, need to trace down where the reverse light wires have been cut by the PO,.. the wire colour should be blue right? ... any help would be great !... thanx.
Chris
Car.
Re: reverse light wiring
October 10, 2010, 12:43:10 PM »
did you check the wires at the switch?
Chris
Car.
October 10, 2010, 12:43:19 PM »
did you check the switch?
buddy boy
Marked for life
October 10, 2010, 01:35:29 PM »
they have been cut by the switch and there's no wire comming from the coil,. thinking if i get it wired up first and then if the switch was bad i would replace it then.
buddy boy
Marked for life
March 18, 2011, 01:50:44 PM »
i'm going to start tackling this problem soon , have another question...
the 2 wires that were cut by the po NEAR the switch , anyone know witch colour wire goes to the lights and wich wire would go to coil ??...thanx !!
BUSDADDY
March 18, 2011, 06:52:01 PM »
Doesn't really matter as the switch just connects them together when you select reverse but the one from the coil #15 is usually black.
buddy boy
Marked for life
March 18, 2011, 08:39:03 PM »
sweet , thanx !!
buddy boy
Marked for life
Reply #7 on:
March 27, 2011, 10:51:52 PM »
thanx again,.. got it working !
Technical
