Author Topic: Difference between early and late beetle door hinge pins?  (Read 6146 times)
« on: October 05, 2010, 05:39:43 PM »
I can't find oversize early hinge pins. However I can find late ones... is there any actual size difference? Its for a 62 bug, and all I can find is 67+ over size ones with no threads...
Re: Difference between early and late beetle door hinge pins?
« Reply #2 on: October 05, 2010, 08:50:13 PM »
Okay to clarify. I want one without mirror threads..... since I'm running albert mirrors and you don't run threaded pins on the bottom.
« Reply #3 on: October 07, 2010, 07:56:27 AM »
Yo Kiki,
I may have some... Give me a call today if you have time 604 760 5899
« Reply #4 on: October 07, 2010, 08:06:23 AM »
You use late pins for early cars on the other three hinges.
« Reply #5 on: October 12, 2010, 08:36:53 PM »
Late hinge pins are wrong for early cars. The early ones have a mushroom style head on them. The later ones were straight all the way and used a plastic plug on the top to keep out water and debris. I assume '67 was the change over year for the later style pins.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111831421A
« Last Edit: October 12, 2010, 08:38:45 PM by Trevor P »
« Reply #6 on: November 29, 2010, 04:23:47 PM »
Trevor is completly right. And the only source as he mentioned is wolfsburg west...
Wish I would of known this a while ago!
« Reply #7 on: November 30, 2010, 04:37:27 PM »
http://www.vintagevans.com.pt/ingles/tipo1_ing.htm
part way down the page
15 euros if you need them isn't too crazy
« Reply #8 on: November 30, 2010, 08:38:14 PM »
or ten euros for this!
http://www.aircooled-museum.com/type1bug-trough-1957-4.php
or maybe too old....
