VW Club Corner
alt light dim
Topic: alt light dim (Read 7326 times)
buddy boy
Marked for life
alt light dim
September 04, 2010, 01:36:05 AM »
when reving the motor my alt light comes on dim , would this be my brushes?... if so, can they be adjusted or do i need new ones?, and where can i buy them ... i have the internal regulator alt.. thanx.
buddy boy
Marked for life
Re: alt light dim
September 05, 2010, 09:39:39 PM »
anyone?
Chris
Car.
Re: alt light dim
September 05, 2010, 10:36:17 PM »
check for loose connections? worn belt? loose pulley?
egspot
Re: alt light dim
September 05, 2010, 11:13:18 PM »
Not a DVKK member.
Assuming your belt os all good.
If the light is fully on when you first turn on the switch.. there is good contact and ground.
If it only does it when you rev the engine, it may be the internal regulator allowing a deficit of voltage...I think, and could also be the brushrs that you mentioned.
I would replace the Alt and save myself some time and efford but it is your call. $$$
Last Edit: September 06, 2010, 04:07:25 PM by egspot
http://www.cardomain.com/ride/2142087
buddy boy
Marked for life
Re: alt light dim
September 06, 2010, 01:47:21 AM »
connections are good , pully/belt is good and new, alt is not that old and it's a bosch ,replaced the internal reg last year..... it's only when i rev it the light comes on very dim
Last Edit: September 06, 2010, 01:52:26 AM by buddy boy
Chris
Car.
Re: alt light dim
September 06, 2010, 09:53:44 AM »
take it off and get it tested, is it edmonds batteries that has the right rig for testing our alternator?
buddy boy
Marked for life
Re: alt light dim
September 06, 2010, 02:29:36 PM »
i'm gonna do the bushings first , there cheap , i'm old friends with the owners son at edmonds starters and alternators.. maybe i'll take it there.
VW Club Corner
alt light dim
