Author Topic: WTB: good used BUS heat exchangers (68-71)  (Read 2313 times)
Offline Type2Meister
« on: August 30, 2010, 04:16:27 PM »
Hi folks,
Looking for some good used BUS heat exchangers (63-71).
I've got some good used ones but they are wrong...the levers are on the inside down low (beetle?)..bus ones are up high on the outside.
Looking for some ASAP as the bus is waiting....
Thanks!
Paul
« Last Edit: March 19, 2011, 12:17:03 AM by Type2Meister »
Offline iceneweb
Re: WTB: good used BUS heat exchangers (63-71)
« Reply #1 on: August 30, 2010, 08:38:52 PM »
You sure about the lever position being wrong? Mine are on the inside (1964).
1971 Westfalia Campmobile
« Reply #2 on: August 30, 2010, 09:31:59 PM »
What year's your bus Paul? 68-71 HE's are quite different from split bus or beetle versions. Unless you can find the replacement ones with both early and late levers. The levers on the outside facing up are for baywindow bus.
« Reply #3 on: August 31, 2010, 10:17:38 AM »
Sorry...just ASSumed that split bus ones were the same as early bay...
I'm looking for the early bay ones for my '70.
I've heard one can open up the sheetmetal around the flap and reverse the lever from the inside to the outside to adapt it.  Heard of this or had any luck doing it?  I really don't want to end up with a Dansk exchanger as I think the VW one is much heavier.
Seen any around?  Should have put the word on the street a little more when I was at the VW show in August I guess!
Offline finkmobile
« Reply #4 on: August 31, 2010, 01:25:27 PM »
« Reply #5 on: August 31, 2010, 02:00:13 PM »
Eric might be able to help you.... http://vancouver.en.craigslist.ca/rch/pts/1923895224.html
Thanks! Called him and he's looking tonight...but if anybody else has some handy, let me know!
It looks like a tricky task to weld a lever to the outside of these bug ones as the shaft is quite far inside the box and not exposed...
« Reply #6 on: March 16, 2011, 10:57:17 PM »
Hey gang,
STILL looking for some decent original VW 68-71 heater boxes for my '70 Westfalia.  If you know of any could you let me know?
Thanks!
Paul
Offline finkmobile
« Reply #7 on: March 17, 2011, 09:51:35 AM »
Poppin' by with another link. Contacted this person yet? http://vancouver.en.craigslist.ca/van/pts/2268155875.html
« Reply #8 on: March 17, 2011, 10:01:50 AM »
thanks...emailed...we'll see!  I will let ya know!
Re: WTB: good used BUS heat exchangers (68-71)
« Reply #9 on: March 21, 2011, 02:39:26 PM »
Still looking for decent 68-71 bus heat exchangers!
Offline airvrt
« Reply #10 on: March 27, 2011, 05:40:56 PM »
hey paul, check your pm.
