Author Topic: ass-backwards bus master  (Read 4899 times)
« on: August 30, 2010, 01:54:43 PM »
So what do the guru's recommend for a 1960 splitty with a dropped bay beam with disc brakes
The little csp 170 buck bay conversion? for a plastic top and small billet adapter for later or just run a splitty master?
Re: ass-backwards bus master
« Reply #1 on: August 30, 2010, 03:04:25 PM »
The split master is single circut, not great. A 67 bus master is dual circut but rare and $$$ Best bet use the late bus master  with spacer from cip/ wolfgang int. Or if you need more stoping power a 944 master but then you need to "t" in a brake light switch.
Jodasa
« Reply #2 on: August 30, 2010, 04:14:33 PM »
Im not the guru you may be looking for, but I agree with Geoff.
I'm running the late bus master with spacer clean simple and cheap... (after you pay the $170 lol).
« Last Edit: August 30, 2010, 04:17:02 PM by Jodasa »
« Reply #3 on: August 30, 2010, 05:35:01 PM »
 I'm sure steve has a bunch of late masters at the bus ranch, all ya need is that spacer dude!
« Reply #4 on: August 30, 2010, 10:07:23 PM »
Don't know what CIP or Busboys sells them for but this guy is selling some fairly cheap http://www.thesamba.com/vw/classifieds/detail.php?id=1002657
Offline pittwagen
« Reply #5 on: August 31, 2010, 01:49:10 PM »
That spacer piece on the Samba looks to be about 3/4" thick.  You could make that pretty quick.  You or Les must have some aluminum laying around.
Offline notchback
« Reply #6 on: August 31, 2010, 08:36:13 PM »
If your making one it's about an inch thick with a step in the middle for the boot to sit against. I would just buy one from Wolfgang they are cheap
Bruce McCrindle
AIRCOOLED WERKS
6047245576
New phone number above
« Reply #7 on: September 01, 2010, 07:44:14 AM »
Im just gonna make one from washers and jb weld..................its a bus it does not need to be safe!
