Author Topic: Got it. Thanks. Delete.  (Read 1264 times)
Offline piercedvw
  • aka Karmann Ghia
« on: August 20, 2010, 10:39:53 PM »
Need one that works..
« Last Edit: August 21, 2010, 10:43:23 AM by piercedvw »
Offline pittwagen
Re: WTB - dual canister vaccume advance dizzy
« Reply #1 on: August 21, 2010, 01:17:49 AM »
Do you still have your original dist?  If the vacuum can is shot, you can buy a new one on Ebay?  That's all that was wrong with mine and it works fine now.  Here's a link I found - there may be others:
http://cgi.ebay.ca/VW-Split-Bug-Oval-Beetle-Bus-NOS-Bosch-Vacuum-Advance-/280549132294?pt=Motors_Car_Truck_Parts_Accessories
There is a number stamped on the arm of the vacuum can that attaches to the dist. plate.  It's also good to take the distributor apart and clean and lube everything as well.
By the way I went with the SVDA - vacuum advance only distributor (Mexican one from CIP1) on my 73 Standard and the car passes Aircare just fine.  Has a bit more zip too.
« Reply #2 on: August 21, 2010, 07:14:57 AM »
The bushings are worn out in hers.
Offline beetlemandan
« Reply #3 on: August 21, 2010, 07:48:47 AM »
i've got one with a busted vaccum pot. if you want it its yours. pm me if you want me to toss it on the bus
the customer is always wrong
« Reply #4 on: August 21, 2010, 07:53:35 AM »
never mind, i just remembered its a single pot
Offline piercedvw
  • aka Karmann Ghia
« Reply #5 on: August 21, 2010, 10:43:00 AM »
Got one. Thanks.
