Author Topic: SOLD - BN4 Gas Heater for a Type 2  (Read 2297 times)
Offline piercedvw
  • aka Karmann Ghia
« on: August 17, 2010, 11:02:10 PM »
SOLD
$50.00 firm.
« Last Edit: August 23, 2010, 09:36:52 PM by piercedvw »
Offline piercedvw
  • aka Karmann Ghia
Re: FS - BN4 Gas Heater for a Type 2
« Reply #1 on: August 18, 2010, 09:50:27 PM »
I've had a number of messages about it. Will get photos up this weekend, unless someone wants to pop by this week to look at it before then.
 It's first with the cash in hand that takes it..  I'm just down from the old Airspeed on 96th in Walnut Grove.
Offline piercedvw
  • aka Karmann Ghia
« Reply #2 on: August 20, 2010, 04:48:58 PM »
Offline iceneweb
« Reply #3 on: August 20, 2010, 05:03:47 PM »
What year van was it from?
1971 Westfalia Campmobile
Offline pittwagen
« Reply #4 on: August 20, 2010, 05:09:34 PM »
Hey that looks fairly complete.  This is likely an early 70's model as it still has the Hardi fuel pump and filter.  Looks like the hot air ducting with the thermostat is present with the control cable.  This one may not have had the fresh air plastic duct.  The timer unit, if it is working, is worth the asking price alone!!  Service and installation manuals are available for these from the Samba and Type2.com.
Note:
Get the serial number and check a couple of the manuals that I noted above.  In any event you don't need the exact year for your 64. You're running 12v right?  It should fit around the gas tank on the left side and the manual will give you the template for the cut out by the wheel well.  Wiring/cables etc are easy to figure out.
« Last Edit: August 20, 2010, 05:17:16 PM by pittwagen »
« Reply #5 on: August 20, 2010, 06:38:37 PM »
That's a 1971 only heater if it matters but would also be correct for a 68-70 with a repaint. No exhaust pipes?
Offline piercedvw
  • aka Karmann Ghia
« Reply #6 on: August 20, 2010, 10:12:55 PM »
It was purchased thinking it would work in my Thing, but it doesn't remotely fit, that's why I'm selling it.
I know nothing about it more than what it looks like. Includes all the pieces shown in the photo.. No more, no less.
I was told when it was purchased that it worked when removed. No guarantees.
Here is the info printed on it:
BN4
2012-95
55114
S-036
Benzin
12
1080-4000
« Last Edit: August 23, 2010, 10:39:42 AM by piercedvw »
Offline piercedvw
  • aka Karmann Ghia
« Reply #7 on: August 23, 2010, 10:40:42 AM »
First with cash in hand gets it.. Sorry.. I can't answer any more questions about it.  The photos and info here is all I have.
Offline iceneweb
« Reply #8 on: August 23, 2010, 01:11:25 PM »
Pls PM me your contact info. I can pickup late this aft (not sure when work is done).
Mark
778 232 5565
Offline piercedvw
  • aka Karmann Ghia
« Reply #9 on: August 23, 2010, 09:36:32 PM »
SOLD
