Author Topic: Rear end shutter  (Read 8613 times)
Offline Schvengy
Rear end shutter
« on: August 10, 2010, 08:51:40 AM »
When driving ...and releasing clutch to gear down ..rear end shutters each time i gear down.???????
recent work done , rear end out to replace hockey stick , clutch plate checked and torqued , rear brakes adjusted , new e-brake cables installed.
Willis
Re: Rear end shutter
« Reply #1 on: August 10, 2010, 03:00:13 PM »
While you are changing gears, or while you let the clutch out?
Offline Schvengy
« Reply #2 on: August 10, 2010, 04:40:11 PM »
when letting the clutch out.
« Reply #3 on: August 10, 2010, 09:58:54 PM »
Put a couple of washers between the bowden tube and the bracket on the gearbox sidecover to give the tube more bend.
A solid center clutch disc is more prone to this type of chatter.  Consider a spring center disc next time the engine's out.
Offline Schvengy
« Reply #4 on: August 16, 2010, 02:35:36 PM »
I had added 2 washers when i changed the cable about a month ago, took one washer out today and there is no more chatter .
Willis
Offline VW 144th
  • Luck happens when preparation meets opportunity
« Reply #5 on: August 16, 2010, 08:32:35 PM »
Willis
Check all your transmission mounts and see if they are split  2 rear one center front,it sounds to me like your front trans mount shit the bed!
J
88 syncro doka
70 bug
62 bug
Offline Schvengy
« Reply #6 on: August 18, 2010, 08:21:13 PM »
Took out one washer and it cleared the 3rd gear shutter but still the same in second gear. Will check em J ..thanks
« Reply #7 on: August 19, 2010, 10:15:18 PM »
Hey Schveng , its not really about .... one washer for this... two washers for that . Its about getting a good bend in the bowden tube so that any movement of the trans will not have an effect on the operation of the clutch. Otherwise it starts a brutal back and forth cycle (chatter).    Could also be a combo of many things
« Last Edit: August 19, 2010, 10:18:13 PM by Hansk »
