Author Topic: Tuning problem  (Read 3699 times)
Offline flat4
Tuning problem
« on: August 03, 2010, 12:18:46 PM »
I've been working for a few hours trying to tune my friends 1904.  He's running dual 36 dellortos.  The issue I'm having is with the mixture screw on #4.  When adjusting all the way in/out, it doesn't change the idle speed of the engine in the slightest.  With 1-3, when the mixture screws are turned, idle either drops or increases (to a point).
We pulled the idle jets, cleaned them out, cleared the carb body (with air), cleaned the mains, replaced the rubber washers on the idle stacks, and still nothing.
I thought it might be a vacuum leak, but was unable to locate one.
Totally stumped, and looking for suggestions.
Thanks!
Fred.
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Re: Tuning problem
« Reply #1 on: August 03, 2010, 01:55:44 PM »
How are the shafts and bearings? Greased the gaskets? Did you compare the mixture screw to the others for wear?
