Author Topic: Link Pins Adjust/shims  (Read 3558 times)
« on: April 29, 2004, 05:24:22 PM »
Okay so both my link pins have play on the bottom.. Probably a result of me misplacing a shim or Anyways they both have play coming from the bottom. So its just a matter of buying some shims and placing some underneath right?
-kirin
(Vehicle in question is a 62 beetle)
« Reply #1 on: May 02, 2004, 01:37:41 PM »
how many shims have you used Kirin?
you should have 8 in there now depending on the measurement it will change howmany are in the front and how many are in the rear but it should always be 8 shims
russ
