Author Topic: FS '67 custom bug  (Read 1455 times)
Offline Friday67
  • Junior Member
FS '67 custom bug
« on: July 26, 2010, 06:25:33 PM »
1500 single port converted to a 1641 duel port. .043 heads, .009 distributor, 110 angle cam, duel kadrons, four pipe monroe exhaust system cromed,  crome engine back and side plate with green engine light. louvered deck lid.adjustabeam front end. notch lowering rear, seals replaced, lowered 2 notches already.new rear hubs, newer tires, and vw mags and vw moon caps<5 bolt> front end converted from 67-65 shaved fenders, porche headlights and turn signals, scat shifter.things that still need to be done, or redone, replace pan,The pan has been undercoated, but is still starting to rust out by the battery on passengers side.This is a comon problem with these cars. rockers, front apron needs welding, and some door work.it is running, and has been aircared in the past.asking $2500, reasonable offers considered.
« Last Edit: August 27, 2010, 09:40:49 AM by Friday67 »
Offline sketchyvw
Re: FS '67 custom bug
« Reply #1 on: August 27, 2010, 05:04:34 AM »
Can you please send pics of the datsun!!! Interested :)
Offline Friday67
  • Junior Member
« Reply #2 on: August 27, 2010, 09:35:25 AM »
Sorry the Datsun is gone, I will remove that part of this post!
