Author Topic: VW Parts Part II  (Read 999 times)
Offline 62bugg
VW Parts Part II
« on: June 10, 2010, 08:28:04 PM »
Heh guys as promised here is the second wave of things, good for people restoring or hoarding
1. Beetle 1960-1966 Door Handle Seals Full Set $1
2. NOS Door Panel Inserts around 50 or so $5
3. 2 Bags New 113-857-219 Rubber Caps $4
4. 1 Bag new door panel clips $2
5. Small bag around 20 Body MMould Kit Grommets $2
6. 1 New Tail Pipe clamp $1
7. 19 sandblasted and primed original wheel lugs $5
8. Original Washer for bug out of a 61 i believe $5
9. 4 valve cover gaskets cork $2 for all
10. Brake fluid resevoir screw on cap and plastic nipple $2
11. NOS Door Switch Boots 2 for $2 113-947-565
12. Bunch of headlight hardware, clips, sprints etc $5
13. I have a bunch of parts heater stuff i believe thats been sandblasted and painted if you come look at the other stuff i will show you if interested
14. 2 New 113 198 031 gasket set $2
15. 2 New 111 198 031 gasket set $2
I live in Maple Ridge but can bring the parts to Burnaby Mon-Fri
Cheers
Rob
 :O0:
« Last Edit: June 10, 2010, 08:39:06 PM by 62bugg »
