Author Topic: Looking for parts (listed) Oval & later  (Read 1098 times)
« on: May 23, 2010, 11:44:01 AM »
Looking for the following parts for a beetle project:
screw terminal ignition for oval
used running boards (German) need to be solid
E-brake assembly (have the handle and bottom clip..need all the guts & a black button)
screw terminal domelight
screw terminal snowflake tail light bulb holders (& one tail light screw if anyone has)
oval pedal assembly (or at least the clutch arm part)
clutch cable release arm (on transmission - curved arm '62-ish)
used drivers side front rubber floor mat ('56-'59)
early door panel clips (as many as you have if in good shape)
wolfsburg hood crest (with good tabs)
will be adding to list
« Last Edit: May 24, 2010, 10:25:27 PM by vwboop »
Offline surgerypending
Re: Looking for parts (listed) Oval & later
« Reply #1 on: May 23, 2010, 12:17:15 PM »
Hey, ive got a couple boxes of oval and early bus parts. Not exactly sure of the contents but if you want them come get em! Free...but you gotta take them all!
Offline stefan
« Reply #2 on: May 24, 2010, 02:45:59 PM »
i,m sure i have most or what you need!    you should know better! lol_hitting
