Author Topic: New Sachs presure plate ,kush lock disc,12.5lb flywheel  (Read 1212 times)
« on: May 09, 2010, 07:53:51 PM »
New 12 lb flywheel, lightened 8 dowel.
New Sachs 200mm 71-79 presure plate
New Kush Lock disc
All for $125
Offline california
Re: New Sachs presure plate ,kush lock disc,12.5lb flywheel
« Reply #1 on: May 13, 2010, 08:21:34 AM »
Hi Geoff
 I HAVE A 1600 ENGINE OUT OF A 74 AUTOMATIC CAR. COULD I USE THIS SETUP TO HOOK IT UP TO A STANDARD TRANNY
 THANKS
« Reply #2 on: May 13, 2010, 12:55:39 PM »
Yes, all that will work.  Your new gearbox will need to be the later type with the guide tube for the TO bearing.  If it isn't, there is a press-in adapter tube that acomplishes the same thing.
Offline california
« Reply #3 on: May 13, 2010, 08:07:02 PM »
Great thank you very much. :D
Offline california
« Reply #4 on: May 14, 2010, 07:44:08 AM »
pm sent
« Reply #5 on: May 16, 2010, 09:40:02 AM »
sold
