Author Topic: how big can i go: 15in on 3.5in low 64 bus  (Read 7324 times)
Offline iceneweb
« on: May 05, 2010, 07:34:43 AM »
Getting my spindles flipped, and have lowered the rear a spline so bus will be 3.5 in lower.
I want to keep the gearing up for the freeway, so what are the tallest tires I can put on either 14in or 15in wheels (haven't decided yet)?
Thanks,
Mark
1971 Westfalia Campmobile
Re: how big can i go: 15in on 3.5in low 64 bus
« Reply #1 on: May 05, 2010, 05:13:48 PM »
What gearing do you have now?
Straight axle swap, or still reduction boxes?
How much hp?
Offline iceneweb
« Reply #2 on: May 11, 2010, 08:48:11 PM »
Hi Bruce, everything else is stock, otherwise I would have mentioned it in my original post.
I got an answer to the question of what is the tallest tire/wheel combination I can fit to a 3 1/2 dropped bus:
195/75/14
205/65/15
Or thereabouts. . . . ;)
« Reply #3 on: May 12, 2010, 08:34:15 PM »
You shouldn't go much taller than stock, you don't have the hp at lower rpms to push that bread loaf at freeway speeds.
Offline StubbornMule
  • www.stubbornmule.ca Wicked Coffee
    • Fresh Roasted Coffee
« Reply #4 on: May 07, 2011, 10:25:23 AM »
My rears I have 215/65/15 BF Goodrich it makes removing the rear wheel tough (you need a bar to unspring a bit to remove)  but once it's on and the bus dropped down they tuck in and don't rub.  They are nice and fat looking.   there is a wheel tire suspension thread on The Samba that you should check out...there are tons of examples.
Offline iceneweb
« Reply #5 on: May 08, 2011, 04:01:59 PM »
That was an old post. Since then I have found that in the rear I can just squeeze in 185/60/15 and for the front, 175/55/15. Thanks
