Author Topic: flycutting heads  (Read 4721 times)
Offline beetlemandan
flycutting heads
« on: May 02, 2010, 05:40:54 PM »
i'm going to put my ported and polished heads (stock valves) on my 1641 (balanced and blueprinted, with an engle 110)
the heads still have the lip on the sealing surface and i want to bump up the compression. how much should i machine off? i'm not running any spacers under the cylinders.
i'm really sick of losing to a stock 280z at the drag strip >:(
the customer is always wrong
Re: flycutting heads
« Reply #1 on: May 02, 2010, 05:55:44 PM »
What's your current deck height?
« Reply #2 on: May 02, 2010, 09:36:45 PM »
d'oh!!!!!. seeing as the heads are still on and the engine is in the car running, it may be a while before i can answer that question. i'll keep you posted.....
