Author Topic: Seat belt brackets  (Read 1964 times)
Offline Batan
Seat belt brackets
« on: April 19, 2010, 11:25:38 PM »
Anybody know where to get a set of these locally? I got some Vanagon retractable seat belts for my bus but I need L-shaped brackets to mount them in vertical position.
http://wescoperformance.stores.yahoo.net/boltkit.html
- Ermin
'69 Riviera Bus
'74 Super Beetle
formerly '61 Ghia
duostyling
Offline G-dog
Re: Seat belt brackets
« Reply #1 on: April 20, 2010, 08:26:47 AM »
I think I have some in my collection of crap.....I found 4 of them.
« Last Edit: April 20, 2010, 08:44:47 AM by G-dog »
Offline pittwagen
« Reply #2 on: April 20, 2010, 09:02:41 AM »
Well the brackets are cheap enough, then when you calculate the shipping costs - wow!!  I'm sure you could find some local shop that would have these or something like them - Mopac in Langley, Lordco, Overseas Auto.  I need to do the same thing for my van - new seats and retractable seat belts.
In my Bus (79 and no bulkhead on either side)  the existing seat belt bolt hole (center) is about 3 1/4" forward from the edge of the rear wheel well.  If you want to get the seat belt retractor rearward as far as possible, I would make the bottom bracket a little longer than what you have here.  It looks like it will only move the retractor back at most about 1" and might cause the retractor to hit the seat, depending on the type of seat you have.  Having a longer base will also allow you to rotate the braket slightly towards the door post as well, if added clearance is needed.
I'm hoping to use either Vanagon seats or PT Cruiser seats to replace the horrible stock vinyl ones.
My thoughts.
Offline Batan
« Reply #3 on: April 20, 2010, 10:50:23 AM »
My thoughts.
Exactly, 10 for the brackets and then 35 for shipping!  ::)
I have stock early seats(so Vanagon seats don't fit). I've seen them(the belts) installed in Bays on The Samba with no modification though, just the bracket. I will eventually end up with 911 seats I'm rebuilding/reupholstering. People make their own brackets from angle iron, but living in an apartment building, cutting and drilling angle iron one thing I don't have tools for nor space.
I PMed you.
« Last Edit: April 20, 2010, 10:54:02 AM by Batan »
- Ermin
'69 Riviera Bus
'74 Super Beetle
formerly '61 Ghia
duostyling
Offline finkmobile
« Reply #4 on: April 20, 2010, 02:08:58 PM »
CIP1 might have something like that.
Offline Batan
« Reply #5 on: April 20, 2010, 02:20:30 PM »
I thoughts so too but now. It seems like I'm getting a pair from Gary! PDT_Armataz_01_37
- Ermin
'69 Riviera Bus
'74 Super Beetle
formerly '61 Ghia
duostyling
