Author Topic: Aircare Blues....hehehehe  (Read 2931 times)
Offline AlanU
« on: April 19, 2004, 12:46:34 PM »
2332, IDA's, CB2289 cam, 140gph electric fuel pump, 46 x 38 heads and look at my emissions......hehehe. Its all about tuning. Called a 30mm stock carb hehehe
« Last Edit: April 19, 2004, 12:51:55 PM by AlanU »
Offline Hoosier Daddy
« Reply #1 on: April 19, 2004, 12:50:40 PM »
My guess is your 2332 fell out on the way to aircare and somehow a single port fell into your car :D
« Reply #2 on: April 19, 2004, 01:19:27 PM »
Nice Job Allan.
Offline Cameron
« Reply #3 on: April 19, 2004, 01:20:37 PM »
Alan!
What was causing your motor to run so poopy? I remember you saying that it stumbled a lot, would not rev up, on  Sunday morning.
Offline 1969deluxebus
« Reply #4 on: April 19, 2004, 01:22:43 PM »
mad props
matt street :rockon:
Offline ehos
« Reply #5 on: April 19, 2004, 02:43:01 PM »
Just goes to show how emissions testing is a money grab.  Thank God Alberta's rich and we don't have that here (yet, knock on wood!).
Offline AlanU
« Reply #6 on: April 19, 2004, 03:24:58 PM »
Alan!
i dont know what happened it was running real bad when the engine had load and then it suddenly cleaned up. I must have been the rust forming while it sat for 3 yrs . That Superstore presidents choice 15W40 must have been the special elixer  :huh:  :lol:
5% CO before the 4 gas analyser told me to tweek. Funny thing is that it still would of passed even in that  crappy tune state.
« Reply #7 on: April 19, 2004, 04:31:11 PM »
So was that just your stock 1600 motor?
« Reply #8 on: April 19, 2004, 04:42:56 PM »
Interesting..
I'm going to be finding a place with a gas analyzer before or maybe after I attempt to take Seabert through Aircare next weekend..
-Kirin
Offline AlanU
« Reply #9 on: April 19, 2004, 06:09:56 PM »
Geoff,
its 1500cc  single port I think or maybe 1600.  009 dist w/ 3yr old corroded points (dwell adjustments?? whats that hehehe) and no charging system cause i didn't feel like clearancing my alternator to clear the stock carb. The Generator was an excellent idler pulley :P  (extra battery in the back), 5 gallon jerry can behind the seat filled with 94 octane and the fuel hose running from backs seat via the heater channel to the mechanical fuel pump.
Oh the love of volkswagens
« Reply #10 on: April 19, 2004, 06:48:09 PM »
i guess thats the new B.C  system-
-pull motor out in winter !
-freshin up motor for more output !
-install aircare motor !
-pass aircare !
-reinstall fresh motor !
buy insurance for 2 years.
not a bad plan ,maybe you can rent that motor for $25.00 a day
« Reply #11 on: April 19, 2004, 07:01:24 PM »
I was always under the impression the higher the octane fuel, the more emissions?? am I wrong, or was there a particular reason you were running 94 octane??
Offline AlanU
« Reply #12 on: April 19, 2004, 07:57:37 PM »
-pass aircare !
Hmmm good idea Jim. Well actually I can buy 6-7 months this year (in my case April-Oct) then before the aircare expiry date next year I get another 6mths (April-Oct) . So actually 12mths payment for 2yrs. Your
BC System\" sound about right.
Matt,  higher octane is not as volatile as lower octane. 94 is harder to burn.  I simply bought 94 just because.....  Emissions is all about how it burns.  If pre-igniton occurs which means detonation will typically follow would effect the emission output. Higher octane will reduce the chances for pre-ignition so thats why I just bought 94 octane. You never know if the carbon crap in our older engines will pre ignite the cheaper lower octane fuel. So by saying this the higher octane will be more precise in burning fuel when its suppose to.
Higher octane WILL NOT increase emission output. If anything it'll have the same readings as cheaper lower octane (if no pre-ignition occurs)
The problem with AirCare testing is that the stroker engines with larger duration cams will usually have a 2.5\" exhaust/muffler. The probe goes in our muffler and the negative reversion from when the exhaust valve closes creates a negative pressure that sucks air into the muffler. Aircares probe will see a \"Sample of dilution\" which creates a problem. So Aircare thinks you have a massive exhaust leak.  I tested my 2332 with CB2289 cam with a 4 gas analyser and the C02 readings were very low (bad) and the 02 content was very high because of the negative reversion caused by the cam. On the other hand a few years ago my 2110 with Engle 125 and 44 IDF's passed since the duration of the cam is smaller meaning less reversion.
On stock engines you almost NEVER have worry about the dyno test. The idle test is the only concern. The only real method of adjusting dual carbs with a 4 or 5 gas analyser is to remove your muffler and test the individual exhaust ports with a probe at the collector.  Works like a HOT DAMN but wear earplugs. Or its a matter of tweaking 4 mixture screws for a long time.
Offline Pipes
« Reply #13 on: April 20, 2004, 07:17:51 AM »
Congrats man! I mucked with my 1600DP with Dual 40 Kads for about a week and failed air care 3 times!  then motored over to Ed at the bug shop, he threw it on the anyliser and waved his magic wrench and in 30 minutes I was thru air care with a wicked good pass.  :rockon:
Trying for low, show & go
1967 Beetle
« Reply #14 on: April 20, 2004, 08:12:08 PM »
Damn, that's alot of information to comprehend.....thanks Alan!
