Author Topic: where can i find the wheel studs?  (Read 7590 times)
« on: March 09, 2010, 02:23:19 PM »
I have these wheels:
I do have the lugs for them (wil fit right in) and they have a different thread than any other set that i have.
where should i look?
« Last Edit: March 09, 2010, 02:25:22 PM by egspot »
Re: where can i find the wheel studs?
« Reply #1 on: March 09, 2010, 02:27:36 PM »
Need to know what the thread and pitch is on the lugs you've got.
Stock beetle is 14mm x 1.5
If the wheels nuts you have are imperial, not metric, I have a set of adapter studs for you that are likely the ones you need.
« Reply #2 on: March 09, 2010, 04:27:51 PM »
i  have 14mm to 12mm and 12mm to 12mm with several lugs that do not fit into the wheels.
i also have the right lugs that fit into the wheels but the thread if different than my 12mm from my old 64.
« Reply #3 on: March 10, 2010, 10:13:52 AM »
any tire shop can help you.
« Reply #4 on: March 11, 2010, 05:08:47 PM »
You most likely need 1/2 to 14mm studs. The 14 thread to the drum and the 1/2 to the lug bolt.
« Reply #5 on: March 11, 2010, 05:44:23 PM »
Thanks everyone. I will start looking this weekend.
« Reply #6 on: March 11, 2010, 07:00:04 PM »
In which case I have 20 studs which will work.
« Reply #7 on: March 11, 2010, 09:08:28 PM »
Love to see those.
Will pm you.
« Reply #8 on: March 11, 2010, 10:08:33 PM »
I may as well as I have a large assortment of various thread in studs.
« Reply #9 on: March 25, 2010, 06:59:36 PM »
Ceco distributors in poco, I think it is 95 glacier ave?? Mapquest it
They sell all studs and nuts to mosh tire shops
« Reply #10 on: March 25, 2010, 08:14:55 PM »
Thanks man.
I will try them on the week end.
