Author Topic: Valves. For 2l  (Read 4137 times)
Offline love loaf
Valves. For 2l
« on: April 17, 2004, 08:31:50 AM »
so i have a 2L engine and i think all it needs is new valves and or new piston rings.......
can i replace the valves myself.. or do i have to get the valve seats pressed in?  if i cant do it myself  how mutch would it cost me to get it done...
thanks yall :D
Valves. For 2l
« Reply #1 on: April 17, 2004, 09:51:12 AM »
If you have a valve spring compressor  you could change valves your self but so much more is needed .  Heads should be carefully cleaned and inspected for cracks and other damage or wear , guides replaced and reemed,  valve seats resurfaced ,  any reused valves resurfaced,  head to cylinder seating area resurfaced, etc.  Not stuff your likely to do your self and can all add up to probably well over $200 .   I've even know of guy's that will never leave the original seats in bus heads because they are known for falling out , so add on even more $ if you do that .  But once this is all done along with the cylinders honed and new rings  and assuming the bottom end is good ,you should have a very nice running motor.  Hope this helps and good luck.
