Author Topic: ????? 5 x 112  (Read 4055 times)
Offline Alisdair
????? 5 x 112
« on: January 31, 2010, 10:35:47 AM »
trying to figure out wheels for the bugaudi . keeping in mind it started as an audi 86 5000/100
 bolt pattern is 5x112. size is 6.5" x 15  ET 45.
there is now enough room to fit a much different size rim and tire. outside  clearance is not an issue.  brake clearance i dont know yet
my question is do any  vws share 5x112.  i  want to try fit something that would be found on a 55 like BRMs ,raders  etc.
any ideas ?
« Last Edit: February 03, 2010, 10:22:26 AM by Alisdair »
Re: ????? 5 x 112
« Reply #1 on: January 31, 2010, 10:49:51 AM »
A 70s VW Bus had that bolt pattern.  To use wide 5 like your 56 body originally had, you can get wheel adaptors from CIP.
Offline Alisdair
Re: ????? 5 x 112
« Reply #2 on: January 31, 2010, 08:52:53 PM »
thanks bruce   .  i checked CIP,  they have the exact adapter id need , wheel choices are endless  . thanks again
« Last Edit: February 03, 2010, 10:21:51 AM by Alisdair »
