Author Topic: Somebody Must Have These Clips Laying Around...  (Read 1574 times)
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
« on: April 10, 2004, 02:46:36 PM »
It's the clips and clamps that secure the heater cable to the levers on the tubes under the car. If you've got a parts car hanging around, I'll give you $10.00 (that's new retail) if I can come and pull these bits off.
e-mail or cell me at 778-839-0878.
Jason Hamilton
« Reply #1 on: April 10, 2004, 03:28:46 PM »
jc, i may have those, but i'm not sure and i wont be back to the garage until monday. i'll have a look.
Offline Scratchy
« Reply #2 on: April 10, 2004, 04:00:25 PM »
I've made the clampy thingys out of old aluminum VW pushrods.
Cut the rod about 1 inch long. Drill a hole through the rod right in the middle - the same size as the heater cable end.
Take a 6mm tap and run it through the end of the push rod well into the area of the hole you just drilled. Use any 6mm
bolt (10mm head) lying around (can even use the engine tin screws in a pinch).
Viola - that's it!
Works for stock carb throttle cable clamp as well.
Now if only you had some old pushrods lying around.......  :(
