Technical
Engine Tech Forum
Wiseco 94 pocketed pistons?
Topic: Wiseco 94 pocketed pistons? (Read 5108 times)
neil68
November 21, 2009, 05:54:40 PM »
I'm increasing my cam lift and CR on my 2332 cc, such that I'll need to use valve pockets. My 94 Mahles were balanced by drilling under the piston crown by the seller, without my knowledge
Therefore, I'm reluctant to try notching these pistons, take a look at how deep the drilling was in this picture:
So, I was considering using Wiseco 94's or possibly the AA's. Any recommendations from your experience or those you know who have used these kits?
Thanks!
Neil
Der Kleiner Rennwagens
'68 Beetle 2332 cc
12.6 sec at 109 mph
jim martin
If something is priced to good to be true ,do yourself a favour. DONT be a IDIOT and BUY IT
Re: Wiseco 94 pocketed pistons?
November 22, 2009, 04:22:33 PM »
first i would make sure you really need to notch your pistons .have you measured the lift and valve to piston clearance
ie , when i ran a 86c with a hair under .600 lift and 10.5 :1 compresiion i still had 0.220 " piston to valve clearance .
if you are not sure of the correct way to do this let me know
the 'WOK" June 2006 Hot VW's feature car 9.830 sec at 143.44 mph.
Sponsored by :
LUCAS OIL PRODUCTS
www.lucasoil.com
neil68
November 22, 2009, 06:27:37 PM »
Hi Jim,
My 044 heads have been flycut twice and when I clayed the pistons with the 86C,there was ~0.120" valve-piston clearance.
So, I'm thinking with my Web 226, it may get below 0.100". I will clay again and see how it looks.
Thanks,
Neil.
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
jim martin
November 22, 2009, 07:56:29 PM »
Yikes!!!!!
if it turns out you need to notch the pistons let me know and i will give you a slick way to do it for under 10 bucks
Sponsored by :
LUCAS OIL PRODUCTS
www.lucasoil.com
Darren
November 24, 2009, 04:56:33 PM »
Be sure to measure the Exhaust Valve clearance ( it will hit the piston before the Intake in most cases )
neil68
November 25, 2009, 10:07:51 PM »
Thanks for the tip Darren
Neil
'68 Beetle 2332 cc
12.6 sec at 109 mph
Technical
Engine Tech Forum
